Author Topic: E-cigs Redux  (Read 986 times)
Offline GaK_45
  • Sr. Member
E-cigs Redux
« on: June 28, 2016, 03:38:28 PM »
OK. Stupid question time about e-cigs / vape
I have a family member who is thinking about quiting smoking but wants to get into nic vapeing. He smokes 2 packs a day.
I have zero experience in this so I am looking for some recommendations. I dont even know all the parts needed to make a complete kit. Let alone vg/pg ratio 'needed' or nic level (how many is good... but what is 'too good' and risks OD'ing).
Basically what is a good complete kit (with juice) to give to someone to get them off smokes and on to vape. I have no issue mixing and matching or even customization if it makes any difference.
I really have only four criteria that needs to be met (beyond being a complete kits worth of parts)
The parts / kit /etc
1 doesnt suck
2 doesnt cost a fortune
3 will not blow up (ie is idiot proof)
4 will not cause an OD.
Other than that what is a good vape and juice to make a good start pack / 'gift pack'. Recommendations on Canadian stores welcome too!
« Last Edit: June 28, 2016, 03:44:01 PM by GaK_45 »
Illegitimi non carborundum!
Si vis pacem, para bellum.
Offline supaflyx3
  • Commentator
  • Global Mod
  • Sr. Member
Re: E-cigs Redux
« Reply #1 on: June 28, 2016, 05:21:18 PM »
To make things simple, I suggest these two kits for a new vaper.
http://thevaporist.org/Innokin-Endura-T18
or
http://thevaporist.org/Joyetech-eGo-AIO
Each come with 120ML of juice, and with those setups that should last at least a month, if not two. For the Innokin Endura T18 I suggest 18MG, and for the eGo AIO I'd suggest 12MG. The eGo AIO produces a tad bit more vaper, so there for more nicotine intake.
For cheap ejuice afterwards I suggest vjuice ($11 for 60ML, $45 for 250ML) and bargainejuice ($15 for 120ML of juice). It's important to have them try a large variety of ejuice if they decide they don't like vaping, it took me months to find a setup and juice that helped me kick the cravings. Also, tobacco ejuices rarely, if ever taste like a real cigarette. It's more like sticking a cigarette in your mouth and chewing it.
Re: E-cigs Redux
Offline GaK_45
  • Sr. Member
Re: E-cigs Redux
« Reply #2 on: June 28, 2016, 06:30:47 PM »
awesome!
Thanks for the info.
One quick question. What vg/pg ratio would you recommend for juice?
Offline supaflyx3
  • Commentator
  • Global Mod
  • Sr. Member
Re: E-cigs Redux
« Reply #3 on: June 28, 2016, 06:42:30 PM »
I'd say start at 50/50 or 60VG/40PG. PG is for the throat hit, VG is for the "clouds" and smoother. Personally I find anything under 70VG to be a bit harsh on the throat, but thats because I quit smoking over a year ago.
Offline GaK_45
  • Sr. Member
Re: E-cigs Redux
« Reply #4 on: June 28, 2016, 07:32:48 PM »
Any comment on T18 vs T22. It appears that the latter is just a bigger T18 with longer battery life... but you loose that 'cigarette' feel?
Offline supaflyx3
  • Commentator
  • Global Mod
  • Sr. Member
Re: E-cigs Redux
« Reply #5 on: June 28, 2016, 10:05:51 PM »
Yup, thats the only difference! I also suggest picking up a pack of coils, coils last around 1-3 weeks depending on the sugar content of the ejuice that's being used. These are for the T18/T22: https://www.vapornorth.com/collections/innokin-coils/products/endura-t18-coils-canada?variant=16432831175 (also called prism coils on other sites, thats the tank that comes with the T18/T22) and these are the coils for the AIO: https://www.vapornorth.com/collections/joyetech-coils/products/joyetech-cubis-coils-canada?variant=14475376391 I suggest the 1.0 or 1.5 ohm coils for the AIO to start with, the .5 ohm coils are more so for "clouds" and more vapor.
Offline GaK_45
  • Sr. Member
Re: E-cigs Redux
« Reply #6 on: June 30, 2016, 12:35:57 PM »
Thanks! Will do. T22 it is.
Soooo a simple Cool Fire IV TC with Vortex atomo has peaked my interest in my search for a ecig kit for fam. Would this be a decent setup for someone more interested in diving more into the deep end and going right to sub-ohm, max vg, Direct Lung vaping? I'm not one for baby steps nor wasting money.
From what I have seen that innokin will work with basically all inno coils (2 to .1). Soooo if I really like sub-ohm I can go all the way to .1 Nickels or conversely go UP to 1.5 or 2s if I dont like it. Probably wont go below .5 as from what I have read that is when things can get...dicey...and havent read of anyone really going up beyond 1 to 1.5 after trying lower ohm'ers.
Also really like the idea of Temp control instead of wattage control as the coils temps almost has to go up as they heat up at a given wattage (basic physics / elect engineering stuff) and I dont want burnt crap in my lungs.
Am I on the right track with my thinking? Ive only spent 20hours so far investigating so its a bit fuzzy still. Also for TC what would be a good starting point?
Offline GaK_45
  • Sr. Member
Re: E-cigs Redux
« Reply #7 on: July 08, 2016, 11:03:42 AM »
So whats your take on the wismec reuleaux rx200 vs sigelei 213?
I know the rx200 is three 18650s and the sig is two... but that to me doesnt matter.
Go with the more mature model or go for the new and shiny?
