Author Topic: Corsair 800d build.  (Read 8143 times)
Corsair 800d build.
« on: August 23, 2015, 02:18:04 PM »
Day one get the case "check" (thanks forum member Grampa)
Step 1 of new case confirm rad 1 fits "check"
Step 2  find DVD drive for epic Psu relocation mod.... "pending"
Step 3 request new logo stickers and templates from corsair "pending"
Step 4 "pending"
Re: Corsair 800d build.
« Reply #1 on: August 24, 2015, 07:06:58 AM »
Step 2 found broken DVD drive "Check"
Step 3: Request sent this morning along with request for tons of corsair fans. failing that maybe we will go with Bitfenix fans.
« Reply #2 on: August 24, 2015, 08:52:19 PM »
So tonight I did it... I actually did it.
Following tools were broken to make this mod.
1. Cutting wheel (pos cracked on me)
2.3 different dremil bits
3. 2 metal drill bits.
Tools used to succeed at this mod
All above broken tools
1 heavy gage steel cutting scissors
1 power drill with Diamond tip bits
Paper
HAMMER!!!
Pen
Time lots of time
Desire to mess shit up
Also a optical drive and a power supply
After your psu and optical drive are confirmed compatible take apart the optical drive and size it up some more
Then give the optical drives top a breast reduction... make sure she's really flat. Now draw the hole you need for your psu cut out this can be done using the psu and paper or just download a template online
Cut it all up and fit it on the psu
Then fit it in there and admire your work.
My main psu I am using for this build is far less long them the sample one so tons of room.
And that's how I relocated my psu on a corsair 800d. Tons more work to go what do you guys think thus far?
« Last Edit: August 24, 2015, 09:54:55 PM by Soullessone21 »
« Reply #3 on: August 24, 2015, 08:55:51 PM »
Tonight I also removed the lower hdd tray as I need room for watercooling.
Love the cleaned up space think I'll try to find a newer rad :) worse comes to worse these rads will work :D
Also I need fans sponsors and cables... just saying
Offline StaticFX
  • Full Member
« Reply #4 on: August 24, 2015, 09:25:14 PM »
cool idea for the PSU mounting!!
« Reply #5 on: August 24, 2015, 09:29:31 PM »
Thanks, I have wanted to do this mod for some time but could never afford a large enough case. The water cooling in this rig will be great to :)
Still have to paint the mount and fit my ax850 power supply in there.
Online Bond007
« Reply #6 on: August 25, 2015, 06:25:20 AM »
Neat idea. Look forward to seeing the build unfold.
« Reply #7 on: August 25, 2015, 07:53:55 AM »
Thanks, finally figured out what color I will go for my coolant... Blue haha
Now I just need to figure out how I want to mount the lower rads
If I want to remove the Corsair front logo and put a round fan mount there
What Fans I will use as I will need 11 120mm and 3 140mm fans
Also if I should go with LED strips or not. might hit up Ikea and get the color changing ones.
Then I need to logo up the window
Paint the motherboard parts that are yellow and change them to either black, gold or Blue
very tempted to buy this for the front of the case
Then I need to order my waterblocks for my GPU and CPU(Might use a old one I have for the cpu)
Also need to get a pump top kit, going to support Dazmode on that one as he is a cool guy. either 2 of these or
« Reply #8 on: October 08, 2015, 06:04:00 PM »
Gpu block ordered next week WE BUILD!!!
Offline RapidQuick
  • Full Member
« Reply #9 on: October 08, 2015, 06:23:49 PM »
Fallout 4 build?
« Reply #10 on: October 08, 2015, 06:48:00 PM »
Nope rhr build but the fallout vault door was too good to pass up haha
« Reply #11 on: October 13, 2015, 01:51:06 PM »
More parts showed up today :D
Going to mod the HG10 to be something a little different :)
Offline RapidQuick
  • Full Member
« Reply #12 on: October 13, 2015, 05:23:05 PM »
Never seen that before, is it for water cooling?
« Reply #13 on: December 30, 2015, 07:31:24 AM »
CPU shows up this week so the build is finally complete hardware wise.
Got some basic ram last night that goes with the system colors
Only 8GB DDR4 2400 to Start but much more soon
Mini M.2 128GB and m.2 AC wifi card
CPU is a Xeon E5-2630L V3 8Core 16Thread Low TDP of 55W
Still putting this rig into the 800D with relocated PSU.
More updates this weekend
« Reply #14 on: January 03, 2016, 03:11:01 PM »
Shes coming together nicely
Modded the 780 Ti to work with a normal CPU block and a Corsair HG10, will get a better block and some nicer fittings for it shortly.
She's nude and blurry
All new Clothes the HG10 fits nice and is super easy to install
Another angle
More blurry Cellphone pix
Installed into the rig, The sag bothers me so I will get a backplate either from Dazmode or make one myself shortly
