Author Topic: EVGA 980 Hybrid  (Read 1513 times)
Offline GaK_45
  • Sr. Member
EVGA 980 Hybrid
« on: May 23, 2015, 01:04:02 PM »
So EVGA just released a new 980.  The Hybrid.  What do you guys think about this dual approach?  I think its very interesting and as it overcomes classic air cooling limitations for the core, while also negating a large issue with 'factory' waterblocks (they sometimes suck at keeping the rest of the components happy).
Only issue I really see is SLI'ing them would be a bear!
http://www.evga.com/products/Product.aspx?pn=04G-P4-1989-KR
Illegitimi non carborundum!
Si vis pacem, para bellum.
Re: EVGA 980 Hybrid
« Reply #1 on: May 23, 2015, 01:58:12 PM »
Love the design just would love to see a quick disconnect on these coolers so you could swap them into an existing loop or add two together :)
Think it's a step in the right direction but it's already been done http://www.techpowerup.com/mobile/150702/pny-launches-geforce-liquid-cooled-graphics-cards.html
Pny even had a cpu gpu combo closed loop wish I could get a 980 ti with that same setup :)
Re: EVGA 980 Hybrid
Offline Bond007
Re: EVGA 980 Hybrid
« Reply #2 on: May 23, 2015, 04:35:12 PM »
If you have the funds and really want to push the limits (without a dedicated water setup), then go for it. Realistically I would stick on air just because of the added cost. Seems like it's well done though.
Offline yzfraven
  • Sr. Member
Re: EVGA 980 Hybrid
« Reply #3 on: May 25, 2015, 04:33:36 PM »
I like to see some test bench on that card..
Ask Evga to send you one Gak
The price is not to bad compared to some other GTX 980
Offline GaK_45
  • Sr. Member
Re: EVGA 980 Hybrid
« Reply #4 on: May 26, 2015, 07:18:15 AM »
Sure. I will drop them an email and see if they have any samples available. :)
Offline Shiver
  • Guardian
  • Full Member
Re: EVGA 980 Hybrid
« Reply #5 on: January 09, 2016, 02:49:58 PM »
Late to the party on this one, but I think its a good solution so long as you have the room in your case to fit the solution. Since many people are going AIO as well, you tend to run out of real estate quickly.
Otherwise, it is a step forward for sure in keeping cards cool.
-Shiver
