Author Topic: converting charcoal to propane  (Read 1363 times)
« on: March 09, 2015, 09:19:26 PM »
So I had this kick ass weber bbq at work. no one wanted it so I took it. Issue was it's charcoal and I'm too lazy for that.
So I bought a 19.99 mini round propane bbq and used it's propane parts to convert the weber
She's done and she rocks.
Offline supaflyx3
  • Commentator
  • Global Mod
  • Sr. Member
Re: converting charcoal to propane
« Reply #1 on: March 10, 2015, 02:21:14 AM »
Do you sell propane and propane accessories?
« Reply #2 on: March 10, 2015, 06:43:32 AM »
Well I'll tell you what... no :P
but shes done and tonight she goes for the first test drive.
I'll keep you posted
Online Bond007
« Reply #3 on: March 10, 2015, 09:35:40 AM »
You can buy an adapter to convert the connector to accept standard propane tanks as well (20lb vs 1lb). The only issue I have had with larger BBQs designed to run on the small tanks is limited heat....tough to get higher temps, but fine if you slow cook. Let us know how it works for you.
« Reply #4 on: March 10, 2015, 09:37:28 AM »
Thanks Bond, was looking at that option as well, going to get some ceramic bricks today to.
Will keep you posted how it all goes tonight :)
« Reply #5 on: March 11, 2015, 07:43:26 AM »
Worked great last night, issue is I need to adjust the vents underneath a little bit. the heat was good but had a few cold spots.
Burgers were good to haha
