Author Topic: Always connecting/loading info  (Read 961 times)
Offline Bond007
« on: May 27, 2015, 06:45:30 PM »
I meant to mention this a while ago, but forgot. Using firefox on Win7.
While in the forums I quite often have the little green spinning circle on the tabs I have open and it says "Connecting..."
Sometimes similar behavior on my iphone as well.
Not really a big deal, but thought I wouldn't mention it. I believe it started happening after one of the changes made to the site...it wasn't always like that.
Re: Always connecting/loading info
« Reply #1 on: May 27, 2015, 07:01:07 PM »
Can you get me a screen shot next time I'll make the hamster aka Rx00 fix it. We will be running some updates to but it does not take the site down when we do haha.
Offline Bond007
« Reply #2 on: May 27, 2015, 07:15:44 PM »
There you go. And I just realized a tidbit of info on it. The page loads fully (no connecting prompt), but then at pretty much exactly 30 seconds after opening the tab it goes into this connecting thing....like its trying to refresh something or update. Not sure.
I noticed the 30 sec thing, since I tried to open a bunch of tabs to make it happen...they all loaded fine, and then I watching it go to connecting one tab after another.
« Last Edit: May 27, 2015, 07:55:12 PM by Bond007 »
