Author Topic: Enclosed water cooling  (Read 1569 times)
Offline yzfraven
  • Sr. Member
« on: March 08, 2015, 12:44:20 PM »
So what do you guys think is the best closed water cooling for cpu's
right now using the noctua-nh-d14 on my system
but thinking of going to a closed loop water cooling.
like the
 NZXT kraken x60 or 61
Corsair Cooling Hydro Series H110IGT
etc...
Re: Enclosed water cooling
« Reply #1 on: March 08, 2015, 12:58:17 PM »
I have always loved the Corsair aios but have a kraken x61 for my rig that needs to be put in now. I think it's a great way to go and far less massive than the noctua
All and all aio is the best bang for your buck these days it seems
Offline yzfraven
  • Sr. Member
« Reply #2 on: March 08, 2015, 01:17:31 PM »
You will have to tell me the results of your X61, how that performs in your system.
There are so many choices, been reading reviews all weekend. Yes I have exciting life.. lol
prices are from $139 and up I see.
Have not seen any used one for sale yet.
also to add the Enermax Liqtech 240
or the coolermaster my head getting sore... lol
Offline HiTi
  • Newbie
« Reply #3 on: March 14, 2015, 08:08:28 PM »
There is a cooler master glacer 240l rev2 out now as well. Although not a great first review.
I've been wanting to try it for my itx case I have.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103203
Offline yzfraven
  • Sr. Member
« Reply #4 on: March 15, 2015, 04:10:56 PM »
That looks interesting Cooler Master Glacer 240L Ver. 2 , So many out there hard to choose, was going to get the NZXT Kraken 60, but now not to sure.
If I had the cash I would buy like 10 of them and do some testing  see which preforms the best.
Post some results on here..
Nice to see you HiTi on here
Offline Shiver
  • Guardian
  • Full Member
« Reply #5 on: February 01, 2016, 09:48:28 PM »
What did you end up using for yours?
I've personally had great success with Corsair so far (the ones using CoolIt as an OEM).
-Shiver
Offline yzfraven
  • Sr. Member
« Reply #6 on: February 02, 2016, 12:42:51 PM »
Using the  CM Nepton 280L with Noctua 140mm fans, since stock fans were very loud.
So far its doing good job cooling my 4770K @ 4.2GHz 50C load
