Jump to content
News Ticker
  • Join us in our daily conversations to keep up with giveaways and reviews
  • RHR Forums
LACIE RUGGED SSD PRO REVIEW
Recommended Posts
Very recent we took a long hard look at the hunter orange-clad LaCie Rugged SSD 1TB and walked away very impressed with what LaCie had created. That model was a USB 3.1 gen 2 beast. One which it was as rugged as it was fast. As we made mention in that review the LaCie Rugged SSD was not the premier/flagship ‘rugged’ model, rather the LaCie Rugged SSD Pro took that honors. Thanks to the good people at LaCie’s we can show you what this $399 (USD) 1TB model has to offer that the LaCie Rugged SSD series cannot.
Without going too deep into things just yet, these differences vary from the subtle (better data protection) to the blatant (Thunderbolt 3 instead of USB interface) and are how LaCie was able to create a ‘Pro’ model which takes nothing away from the non-Pro variant. Instead is in and of itself a unique model worthy of its own special ‘pro’ moniker. This is rather refreshing as usually when companies create a pro and non-pro model variants… it is nothing more than a cash grab with only slight differences separating one from the other.
That is not the case with the LaCie Rugged SSD Pro. There are indeed a lot of similarities but the obvious time and attention to detail makes this a new and different external storage device. Different in a good way. We will go over the ins and outs of what has and has not changed, but with an asking price a hundred dollars more than the non-Pro model, the burning question everyone will have is simple: is this price difference justified? Is this model really that much better than the LaCie Rugged SSD? Considering how potent and robust the non-Pro model is that is indeed a rather high threshold to clear. By the end of this review you will not only have a firm idea on what each model has to offer, but which will be right for your personal set of circumstances, needs, requirements… and even wants. So, without further preamble let’s take this beauty for a spin.
Read Full Review
  • Like 1
Link to post
Share on other sites
Interesting question. Yes they do state in their specs sheet pdf that you can download. The tricky thing is... its only in the PDF. So it could be changed out at a later date. However, considering LaCie is Seagate and the new drive would have to meet the same specs it is unlikely that they would change it to a worse drive. Most likely if they do change it, they will change the model name. That is usually how Seagate and LaCie do things. 😉
This is the spec sheet for the 2TB'er and it too says what they use:
https://www.lacie.com/www-content/datasheets/pdfs/lacie-rugged-ssd-pro-DS2017-2-2001US-en_CA.pdf
  • Thanks 1
Link to post
I did not know this, thanks for the info GaK.
i know I’m going to need to buy more nvmes and sd cards soon, is there any external nvme drives that are shuck worthy yet or still cheaper to buy on their own?
Link to post
2 minutes ago, GaK_45 said:
You can sometimes find a deal but on average... nope. You will pay a premium for the enclosure vs internal version. It really is only moderately big HDDs where shucking makes sense.
Good to know about the SSDs in externals. HDD are definitely a different story. I grabbed an 8tb WD external for $135 shipped not long ago...it’s crazy, since you would be lucky if you got a 6tb without the enclosure for that price. That said, I don’t plan on shucking it (at least for the time being).
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Who's Online (See full list)
    There are no registered users currently online
  • Newest Posts
    • Máy tính xách tay chơi game thường có giá cao hơn so với các dòng sản phẩm máy tính xách tay thông thường. Tự nhiên để mua cho mình một chiếc máy tính xách tay ưng ý, các bạn cần phải hiểu nhiều về công nghệ. Hãy cùng Techcare - Laptop cu Đà Nẵng tìm hiểu Top 3 dòng laptop gaming đáng mua nhất năm 2021 ngay bài viết dưới đây.  Máy tính xách tay MSI GF63 THIN 10SCXR-1218VN Máy tính xách tay MSI 10SCXR-1218VN không có nhiều thay đổi về thiết kế hơn với các dòng sản phẩm trước đó. Toàn bộ máy tính xách tay vẫn sử dụng chất liệu từ nhựa cứng nhưng vẫn đảm bảo tính chắc chắn.  Laptop MSI GF63 THIN 10SCXR-1218VN được trang bị màn hình 15.6 inch, có viền siêu mỏng chỉ khoảng 4.9mm. Nhờ đó, máy tính kích thước được giảm đi đáng kể nhưng vẫn sở hữu một màn hình lớn kích thước. Xem xét cấu hình, GF63 THIN 10SCXR-1218VN sở hữu cấu hình mạnh mẽ. Với chip vi xử lý Intel Core i5-10300H thế hệ mới nhất cho hiệu suất xử lý tăng 15% so với hệ thống thế giới trước. Về GPU, laptop được trang bị card đồ họa rời NVIDIA GeForce GTX 1650 4GB GDDR6 cho người dùng chiến game mượt mà. Chiếc máy tính xách tay này được trang bị viên pin có dung lượng 3 Cell 51WHr for time use good up to 7 language use. If you are use lien tục, thì khoảng thời gian khoảng 4-6 tiếng (Tùy chọn tác vụ sử dụng). Máy tính xách tay ASUS TUF FX506LI-HN039T Máy tính xách tay ASUS FX506LI được thiết kế nhỏ gọn cùng độ cao khi máy tính vượt qua nhiều chứng nhận của quân đội Mỹ MIL-STD-810G về khả năng chịu nhiệt độ cao, chống sốc và phơi nhiễm xạ hình. Máy tính xách tay được trang bị màn hình kích thước lớn hơn 15,6 inch cùng với tấm nền IPS Full HD sắc nét. Hơn nữa, màn hình sáng cao lên đến 250nits cho các nét ảnh chi tiết. '' '' The shape of the design frame of Nano Edge, công nghệ siêu nguyên khối chỉ khoảng 6,5mm cho độ lớn không hiển thị. Hình dạng với tần số quét 144Hz cho những chuyển động mượt mà, đặc biệt là trong trải nghiệm chơi game. Về âm thanh, ASUS Gaming FX506LI sở hữu công nghệ sưởi ấm HyperCool độc quyền khi được trang bị Hệ thống Làm mát Chống Bụi. Với 3 option tùy chọn quạt chế độ cùng công nghệ Fan Overboost, nhờ vậy mà máy tính luôn có nhiệt độ ổn định, kể cả khi giải trí trò chơi trong thời gian dài. Về cấu hình, máy tính xách tay mẫu ASUS FX506LI được trang bị cấu hình xử lý mạnh mẽ với chip Intel Core i5-10300H thế hệ thứ 10 cho hiệu năng cao. Cùng với màn hình card màn hình kép NVIDIA GeForce GTX 1650Ti 4GB GDDR6 + Intel® UHD Graphics cho phép xử lý đồ họa rất ấn tượng. Người dùng có thể thoải mái sử dụng cho trò chơi giải trí. Tham khảo thêm: laptop choi game tai Da Nang  Máy tính xách tay Acer Nitro 5 AN515-55-5923 Acer đã trang bị cho màn hình tần số quét lên tới 144Hz giúp chất lượng hình ảnh hiển thị sắc nét và không có hình ảnh trạng thái bị vỡ. Màn hình sở hữu có kích thước rất lớn 15,6 inch rất mỏng. Với màn hình cỡ lớn này, bạn có thể sử dụng đa chức năng nhiều ứng dụng cùng một lúc mà không bị giới hạn không hiển thị Acer Nitro 5 được nhà sản xuất Acer trang bị bộ vi xử lý Intel Core i5-10300H thế hệ thứ 10 với tốc độ xử lý cực nhanh với mức xung nhịp lên đến 4,5GHz cho chiếc máy tính xách tay tải nhanh chóng cũng như các tựa game ứng dụng nhanh chóng. Thay thế, máy tính xách tay còn sở hữu bộ nhớ Ram lên tới 8GB cho phép người dùng sử dụng nhiều ứng dụng cùng một lúc. Các bạn cũng có thể nâng cấp dễ dàng bộ nhớ RAM cho chiếc máy tính xách tay lên tối đa 32GB khi có nhu cầu sử dụng cao hơn. Máy tính xách tay Acer Nitro 5 được trang bị card đồ họa rời NVIDIA GeForce GTX 1650Ti 4GB GDDR6 giúp người dùng có thể cài đặt max setting cấu hình phân giải trong game hoặc render những video có độ phân giải cao. Hơn nữa, Acer đã trang bị cho pin máy tính có dung lượng 4 Cell 57WHr help laptop có thể hoạt động liên tục trên 6 tiếng đồng hồ không bị ngắt quãng. Vừa rồi là Top 3 dòng laptop gaming đáng mua nhất năm 2021 mà hệ thống mua ban laptop cu tot nhat tai da nang muốn chia sẻ cho các bạn. Hy vọng với những thông tin này, các bạn có thể chọn mua một máy tính xách tay mẫu ưng ý và phù hợp với nhu cầu sử dụng.
    • Laptop chơi game thường có giá đắt hơn so với các dòng sản phẩm laptop thông thường. Tuy nhiên để mua được cho mình một chiếc laptop ưng ý thì các bạn cần am hiểu nhiều về công nghệ. Hãy cùng Techcare - [b][url=https://www.24h.com.vn/kham-pha-cong-nghe/techcare-dia-chi-ban-laptop-cu-uy-tin-tai-da-nang-c675a1063725.html]Laptop cu[/url][/b] Đà Nẵng tìm hiểu qua Top 3 các dòng laptop gaming đáng mua nhất năm 2021 ngay bài viết dưới đây.  [list][*][b]Laptop MSI GF63 THIN 10SCXR-1218VN[/b][/list]   Laptop MSI 10SCXR-1218VN không có nhiều sử thay đổi về thiết kế hơn so với các dòng sản phẩm trước đó. Toàn bộ laptop vẫn sử dụng chất liệu từ nhựa cứng nhưng vẫn đảm bảo chắc chắn.  Laptop MSI GF63 THIN 10SCXR-1218VN được trang bị màn hình 15.6 inch, có thiết kế viền siêu mỏng chỉ khoảng 4.9mm. Nhờ đó, kích thước máy tính được giảm đi đáng để nhưng vẫn sở hữu một màn hình kích cỡ lớn. Xét về cấu hình, GF63 THIN 10SCXR-1218VN sở hữu cấu hình mạnh mẽ. Với chip vi xử lý Intel Core i5-10300H thế hệ mới nhất cho hiệu suất xử lý tăng 15% so với các thế hệ trước. Về GPU, laptop được trang bị card đồ họa rời NVIDIA GeForce GTX 1650 4GB GDDR6 cho người dùng chiến game mượt mà. Chiếc laptop còn được trang bị viên pin có dung lượng 3 Cell 51WHr cho thời gian sử dụng tốt lên đến 7 tiếng sử dụng. Nếu các bạn sử dụng liên tục thì thời gian khoảng chừng 4-6 tiếng (Tùy vào tác vụ sử dụng).  [img]https://i.imgur.com/5WRU3xI.jpg[/img]  [list][*][b]Laptop ASUS TUF FX506LI-HN039T[/b][/list]   Laptop ASUS FX506LI được thiết kế nhỏ gọn cùng với độ bền cao khi máy tính đã vượt qua nhiều chứng nhận của quân sự Mỹ MIL-STD-810G về khả năng chịu nhiệt độ cao, chống sốc và phơi nhiễm bức xạ mặt trời. Laptop được trang bị màn hình kích cỡ lơn 15,6 inch cùng với tấm nền IPS Full HD sắc nét. Hơn nữa, độ sáng màn hình cao lên đến 250nits cho chi tiết hình ảnh sắc nét. Màn hình còn được thiết kế khung viền Nano Edge siêu mỏng chỉ khoảng 6,5mm cho không gian hiển thị rộng lớn. Màn hình với tần số quét 144Hz cho những chuyển động mượt mà, đặc biệt nhất là trong trải nghiệm chơi game. Về mặt âm thanh, ASUS Gaming FX506LI sở hữu công nghệ tản nhiệt HyperCool độc quyền khi được trang bị hệ thống Anti-Dust Cooling. Với 3 option tùy chỉnh chế độ quạt cùng công nghệ Fan Overboost , nhờ vậy máy tính luôn có nhiệt độ ổn định, kể cả khi giải trí chơi game trong thời gian dài. Về cấu hình, mẫu laptop ASUS FX506LI được trang bị cấu hình xử lý mạnh mẽ với chip Intel Core i5-10300H thế hệ thứ 10 cho hiệu năng cao. Cùng với card màn hình kép NVIDIA GeForce GTX 1650Ti 4GB GDDR6 + Intel® UHD Graphics cho khả năng xử lý đồ họa rất ấn tượng. Người dùng có thể thoải mái sử dụng cho giải trí chơi game. [b]Tham khảo thêm: [url=https://techcare.vn/tu-khoa/laptop-choi-game-cu-laptop-gaming/]laptop choi gaming tai Da Nang[/url][/b]  [list][*][b]Laptop Acer Nitro 5 AN515-55-5923[/b][/list]   Acer đã trang bị cho màn hình tần số quét lên tới 144Hz giúp chất lượng hình ảnh hiển thị sắc nét và không có tình trạng bị vỡ hình ảnh. Sở hữu màn hình có kích cỡ lớn 15.6 inch rất mỏng. Với kích cỡ màn hình lớn này các bạn có thể sử dụng đa nhiệm nhiều ứng dụng cùng một lúc mà không lo bị giới hạn không gian hiển thị Acer Nitro 5 được nhà sản xuất Acer trang bị bộ vi xử lý Intel Core i5-10300H thế hệ thứ 10 với tốc độ xử lý cực nhanh với mức xung nhịp lên tới 4.5GHz cho chiếc laptop load nhanh chóng các tựa game cũng như các ứng dụng nặng nhanh chóng. Hơn thế, chiếc laptop còn sở hữu bộ nhớ Ram lên tới 8GB cho khả năng đa nhiệm mượt mà cho phép người dùng sử dụng nhiều ứng dụng cùng một lúc. Các bạn cũng có thể nâng cấp dễ dàng bộ nhớ RAM cho chiếc laptop lên tối đa 32GB khi có nhu cầu sử dụng cao hơn. Laptop Acer Nitro 5 được trang bị card đồ họa rời NVIDIA GeForce GTX 1650Ti 4GB GDDR6 giúp người dùng có thể cài đặt max setting cấu hình độ phân giải trong game hoặc render những video có độ phân giải cao. Hơn nữa, Acer đã trang bị cho máy tính viên pin có dung lượng 4 Cell 57WHr giúp laptop có thể hoạt động liên tục trên 6 tiếng đồng hồ không bị ngắt quãng.  [img] https://i.imgur.com/hUTN8Jm.jpg[/img] Vừa rồi là Top 3 các dòng laptop gaming đáng mua nhất năm 2021 mà hệ thống [b][url=muabanlaptopcudananggiare.peatix.com]mua ban laptop cu tot nhat tai da nang[/url][/b] muốn chia sẻ cho các bạn. Hy vọng với những thông tin này, các bạn có thể chọn mua một mẫu laptop ưng ý và phù hợp với nhu cầu sử dụng.
    • Range of adjustment: If you want an adjustable computer desk that has the facility to sit and stand, it requires to lower to the point where you are relaxed while working in a rested seating position.   Depending on your height, the height of your chair, etc, this could be very low. And it requires you to go up to your standing work position, again depending on your height this can be pretty high.   Drive Method: If you plan on actually adjusting your desk you need some way to move it up and down. Electric is the most comfortable for the user, and most complex technically. Crank is the most cumbersome on the user but is the simplest design-wise and the cheapest. Pneumatic is in between the other two.   There are a couple of other solutions. Particularly if you choose an electric drive, the table should have some type of automatic stop, so you don't smoosh your legs when lowering the desk.   Aesthetics: A lot of adjustable desks are kind of similar looking, the ones that are not can be a bit costly.   Price: Adjustable desks are just plain expensive desks. If you find an inexpensive one be wary you may be getting what you pay for. If you are looking for computer supply then visit the Computer Supply Store.
    • Hôm nay Arinoth bước ra khỏi giấc ngủ đông lạnh của mình và đi lên thang máy của hầm 111 và có một cái nhìn sâu sắc và chi tiết về Fallout 4. http://www.realhardwarereviews.com/fallout-4/ http://www.realhardwarereviews.com/wp-content/uploads/2016/05/Fallout4-2016-05-24-21-21-31-96-1024x576.png Hy vọng rằng trong tất cả các DLC tiếp theo, liệu DLC sắp tới có phải là vị cứu tinh của Fallout 4 hay không, tôi chắc chắn hy vọng như vậy.
    • Hello everyone, now I am choosing between several laptops, but maybe you can advise me something better my priorities: mostly just for home, for watching movies and YouTube, for some light games (a couple of times a month), and sometimes for work (mostly google drive, various marketing resources, nothing heavy) around 600 USD 15.6" or more Acer, Asus? Order on Amazon? Windows prefarable 256 SSD or more. I will leave links of those notebooks that I am thinking about now https://www.amazon.com/Acer-A515-44-R41B-Hexa-Core-Processor-Graphics/dp/B087N4ZRXV?ref_=Oct_s9_apbd_simh_hd_bw_b2N0e&pf_rd_r=61THRATEMWAKYQZB6J7M&pf_rd_p=121acd9e-769b-5530-ae68-5a92ebd704d6&pf_rd_s=merchandised-search-10&pf_rd_t=BROWSE&pf_rd_i=565108 https://www.amazon.com/Acer-A515-55-56VK-i5-1035G1-Fingerprint-Keyboard/dp/B087RTV311/ref=sr_1_10?dchild=1&qid=1613042065&rnid=13896617011&s=computers-intl-ship&sr=1-10 THANKS!   Cali employee monitoring software
  • Create New...
