So what do you guys think is the best closed water cooling for cpu's
right now using the noctua-nh-d14 on my system
but thinking of going to a closed loop water cooling.
like the
NZXT kraken x60 or 61
Corsair Cooling Hydro Series H110IGT
etc…
I have always loved the Corsair aios but have a kraken x61 for my rig that needs to be put in now. I think it's a great way to go and far less massive than the noctua
All and all aio is the best bang for your buck these days it seems
You will have to tell me the results of your X61, how that performs in your system.
There are so many choices, been reading reviews all weekend. Yes I have exciting life.. lol
prices are from $139 and up I see.
Have not seen any used one for sale yet.
also to add the Enermax Liqtech 240
or the coolermaster my head getting sore… lol
There is a cooler master glacer 240l rev2 out now as well. Although not a great first review.
I've been wanting to try it for my itx case I have.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103203
That looks interesting Cooler Master Glacer 240L Ver. 2 , So many out there hard to choose, was going to get the NZXT Kraken 60, but now not to sure.
If I had the cash I would buy like 10 of them and do some testing  see which preforms the best.
Post some results on here..
Nice to see you HiTi on here
What did you end up using for yours?
I've personally had great success with Corsair so far (the ones using CoolIt as an OEM).
-Shiver
Using the  CM Nepton 280L with Noctua 140mm fans, since stock fans were very loud.
So far its doing good job cooling my 4770K @ 4.2GHz 50C load
  • 7
    Posts
  • 2683
    Views
